Here we go again - Window rolled down by itself
Macan 4
I was heading to the grocery store, and as soon as I got out of the car and started walking away, I noticed the driver's window was halfway down. At first, I thought I must have forgotten to close it, but I hadn't even touched the window, and I rarely lower it in the first place. So I got back in, rolled the window up, and as soon as it reached the top, it immediately dropped halfway down again. This happened 2–3 times—it simply refused to stay closed and kept lowering itself halfway.
Eventually, I rolled the window all the way down and then back up again, and after that it started working normally.
Now, this could just be a one-off issue and nothing to worry about, but the Macan EV had some pretty dreadful window issues on early production cars (opening itself on locked cars etc). Because of that, I'll call my dealership tomorrow to get ahead of it before it potentially becomes something bigger.
Has anyone experienced anything similar with the Macan, or have any idea what might cause this?
Macan 4S (EV) awaiting Coupe
This is really bad but this might resolve it. (Apologies if you know and have already tried this). I remember reading this on the Macan forum and elsewhere - the windows reset. I suggest you try it before you call so the dealer knows it’s not a reset issue, also it seems very close to what you did to get it closed
If the problem persists then do the following procedure to calibrate the limit switches:
1- Lower the window while holding down the button at the first click.
2- Press to the 2nd click and hold for 6 seconds.
3- Raise the window while holding down the button at the first click.
4- Press to the 2nd click and hold for 6 seconds.
Hope you get it sorted and it isn’t a portent of troubles starting.
Macan 4
I really appreciate it. I will make sure to try it because I haven’t even though it seems I did something similar by accident.
Sadly, I know from experience that “resets” usually don’t work on Porsche EV problems 😂
Audi R8 V10, Cayenne EV (on order), BMW iX3 (on order), MB C-Class, Renault R5
I had this on my Macan a lot, and it sounds like the window needs recalibrating. Follow that procedure and I suspect it will solve it. Of course, you'll probably have the issue repeat itself in a few weeks or so.
Macan 4
I am sorry to hear that, I hope your Cayenne experience will be better. Thanks for noting that, I will take it seriously with the dealership if that is the case.
Damn. This kind of report makes me skittish. The continual delays on my order don't help. Lastly, I just completed a nine day holiday with my family driving around northern California Redwood territory and San Francisco in a Tesla. Used the Full Self Driving for 99% of the drive and it was so impressive.
Macan 4
Sounds like a nice holiday! :)
This isn't a widespread issue, and I've had no other faults or anything even close to the Taycan (First gen) or Macan. Usually, Porsche is pretty adamant about dealing with the issue quickly and provide loaners. This is something that should get fixed pretty fast, and if you're not overly sensitive like me (due to my last Macan 4 that was a lemon) It wouldn't really matter.
As I always say, for every Porsche EV-owner that shouts in the forum about something, there are one hundred similar owners that sit quietly in the cars enjoying them without an issue.
ex Macan 4S's
Had this issue once on Macan, and as describe by @Wivenhoe, that did the trick (my sales person did it) and never reoccurred. So far I have no issues with my Cayenne except some minor seat position glitches in the first week - could have been me playing round with all possible settings.
ex Macan 4S's
My past experience with 2 Macan luckily is blurred, but from recollection, there were some wide spread issues like automatic flap doors and Plug and charge for example (so guess quite a few more unhappy customers). Early days, but by the looks on the Forum, totally different experience. All about colours, wheels and options as it should be.
Macan 4
Quick update: Spoke to the head of the service department and he told me the obvious answer: Do the reset as stated by @Wivenhoe (thank you again) and see if it happens again.
In sum: I probably overexaggerated :CWL:
dcarissi
Dan
Southern Pines, NC
Macan
Which Cayenne EV was this happening on?
I had 2 Macan 4S EVs last year with this issue and don’t want to go thru it again….
