Adaptive Cruise Control Issue
I have the same setup like @Wivenhoe so usually notice this straight away. In first scenario I usually take over for a short period and cruise control will continue afterwards. I am not saying it’s better than human driving, but like you I like to drive by night and it takes off some strain. Each to their own. Same for automated lane change.
Luminated67
Northern Ireland
Porsche Cayenne S Coupe EV
On the Macan you could select Cruise Control or Adaptive Cruise Control by pressing the button on the end of the stalk and then selecting in the left tube. According to the online manual there should be 2 separate choices for plain cruise or adaptive. Apologies if the manual is wrong, I use adaptive and never used cruise control. I have a HUD and so I see the speed dropping, indicate and the car checks it’s safe and pulls out.
Maybe the manual is generic and covering for all options, i.e. cars equipped with adaptive cruise and cars equipped with regular cruise.
The manual is covering for cars that have or don't have Adaptive Cruise Control. If your car has Adaptive Cruise Control, then there is no way of operating it without the "adaptive" part. There is no "Cruise Control" option in the left tube. There should be, and they should give you a choice, just like BMW.
When Adaptive Cruise was an option, like on my Macan Turbo which I sold in February, it wasn't an issue. I just didn't spec it. Unfortunately, the new Cayenne has Adaptive Cruise as standard, which means I will have to work around it. It's absolutely nuts that I have to "work around" a feature on the car when I'm spending £150,000. Just give me the choice!!
Will need to check if that’s still possible on my i5 before it comes, if it’s possible on it then it’s in one of the many menus because it’s not on the cruise control buttons.
It's definitely possible, as I used to own an i5. It's buried within the main menu settings in the iDrive.
How to Switch to Cruise Control Without Distance Control
    • Open the BMW iDrive screen menu.
    • Select Vehicle Apps (or Apps).
    • Go to Driving Settings.
    • Choose Driver Assistance, then select Driving.
    • Tap on Distance or Distance Control.
    • Select Switch to Cruise Control to disable adaptive distance.
You can select it as a shortcut, which is what I did. You do have to reselect it at the start of every journey, though.
Luminated67
Northern Ireland
Never knew that though to be honest the i5’s adaptive cruise control has been faultless so wouldn’t have needed to make the switch. The wife’s Golf R also has adaptive cruise and it too hasn’t had an issue, I still think could it be caused by dirt on the camera in the windscreen because when my i5 had been covered in snow this wouldn’t work until the snow and all condensation had cleared
That's another fault with adaptive cruise (on some cars, at least). A few years ago I had to drive from Southern Holland to Hamburg in a rental Nio ET7. A journey of many hundreds of km. It was winter, and there was a small bit of sleet for most of the journey. Within a few minutes of setting off and joining the motorway, a very small layer of sleet had developed at the top of the windscreen. Immediately, the adaptive cruise was no longer available due to the camera being obscured, even though the sleet wasn't that bad (the roads were completely clear). The problem was, I couldn't even use it as a "dumb" cruise control. So I had to drive for six hours without any cruise control, without any reason at all. Utter madness.
Looked at the manual, some scenarios @Throb and others mentioned are highlighted as problematic. So agree, there should be an option to turn it off if driver wishes too. Some cars allow you to turn off ESP completely which is plain dangerous on public roads. Even Maylaender leaves it on in safety car.
Apologies. I was wrong. I checked my car this morning and unlike what it says in the manual, there doesn't seem to be an option for cruise control only. I'm not sure what the assist selection does though.
BayouTiger
Chuck
Mid Tennessee
26 Cayenne Electric Turbo, 25 GMC Sierra EV Denali Max
ESP is a completely different thing and something that Porsche excels with. Guys turn off ESP to be able to drift and do burnouts. Sometimes you need the rear to break loose a bit.
During 2 day winter training (a long, long time ago) we got some insights into various settings, usually car manufactures do not allow to turn off ESP completely (except performance cars requiring training to enable all settings). My SL was drifting slightly in normal setting, ESP would kick in later by default. We played around with ESP on dedicated snow tracks. If you were to turn off ESP (only partially by default) announced (as passenger :devil:) on S class (no 4 wheel drive) in corner (ice/snow), driver would loose car every time due to usual speed (from recollection you would need to reduce speed by 10-20 kmh for cornering without ESP). In S class with 4 wheel drive you could recover car at times (not sure why Porsche is offering SUV without 4 wheel drive). Not sure how ESP settings work in Porsche, guess I will find out during driver training.
BayouTiger
Chuck
Mid Tennessee
Turning off ESP in icy/wet conditions would not be smart. I don’t turn it off on the track in a Porsche, but in my old Challenger it was not possible to run a fast lap with it on.
Luminated67
Northern Ireland
Less sophisticated ESP systems will require its removal to deliver a quick lap but a lot of the better brands have fine tuned theirs so well that you would really need to be a semi pro racer to lap quicker with it off than on.
BayouTiger
Chuck
Mid Tennessee
Exactly.
BayouTiger
Chuck
Mid Tennessee
Update on the ACC issue. It’s been back at the dealer since Friday and Porsche has them pulling the bumper cover and going through the sensors and plugs/harness. Suffice it to say, very disappointing start to a very expensive car!
edit: sensors OK, now waiting for Porsche to throw the next dart at the wall. I’ve asked if they have done/considered a full reprogram of the car, but no answers. some have said that similar issues on their Macan was fixed with reprogram.
BayouTiger
Chuck
Mid Tennessee
Another week gone. Car still sits at the dealer. They changed the ACC Camera as Porsche recommended but still cannot get the software to calibrate. Right where we were after a week of PDI before they finally delivered and now three weeks in.
I went through over a year dealing with a Taycan that they could not fix until they finally got it working after keeping it for 11 weeks. I am not going to deal with this much longer. Day 31 it goes to a lemon law lawyer. I said I would not buy another Porsche, especially an EV, but here we are. Getting very frustrated.
Sorry to hear, you seem to be the first on this forum with major problems. Have been there before, 2 Macan EV lemons. My Cayenne seems fine so would recommend to friends. There are currently some delays in delivery/build so not sure if they identified problems with some parts. Electric cars are complex and unlike Apple, not all components are designed in house and production monitored vigorously. Chances are it will take them a long time to figure out faulty component/s. If you have an eye on a different car from different brand you like, I would invoke lemon law as soon as possible. Otherwise, I would try to swap for new Cayenne. If you need the size, there is no real competition at the moment (UK). You can spend the 5k from Trump on some nice extras 😂.
