- David
- Jan 28, 2019
- Santa Cruz
- Cayenne Hybrid, 911(s) GT3/Convertable
- Thread starter
- #1
https://www.yahoo.com/finance/news/coming-ev-batteries-sweep-away-140709581.html
it's long been my contention the only problem with EV's is battery weight (but current LiON technology is an acceptable but suboptimal trade off) - and future batteries would drive weight down to below equivalent ICE vehicles - at which point even die hard petrol heads will have concede defeat - batteries are also high modular and can probably be retrofitted into existing designs
now I've been in tech long enough to know that what works in a lab can take decades (or more) to reach production - but still I thought I'd post this.
article states lab has reached .675 kWh/Kg - that means a 94 kWh would be about 140 kg or about 300 lbs - Taycan is currently about 2.7 mile/kWh vehicle but some of that would be due to weight - lower weight would increase Taycan's range - let's say you get to 3.1 miles/kWh due to lower weight - that means you could either lower the total kWh and lower weight even more - or increase range but not use all the "weight budget"...
in any case betting on this stuff is like betting on lottery numbers and I am under NO DELUSIONS that this article means we're soon to have 100 kwH batteries in production for less than 400 lbs - but it's promising none the less and we'll keep chipping away at the problem.
I simply found it interesting and thought I would share…
