gtm
- George
- Nov 5, 2022
- Jacksonville, FL
- '73 Lotus, '23 GTS
Part of my response to you would be why have software/a feature if it's not going to function well? Porsche decided to engineer in a large number of options in the PCM menus. It seems they chose to do it "their way" regardless of how the user experience turned out. It generally gets the job done but it's not easy to master.The only software I consider super important is that giving the steering feel, that blending the regenerative and mechanical braking well, the stability management and active anti-roll bar algorithms.
To the comment on blending the regeneration and mechanical brakes...They did one crappy, scary job on my car. The pedal feel changes with almost every stop. It is very difficult to smoothly move the car an inch or two (approaching a curb or garage wall). It creeps too fast and brakes too abruptly. My car has also developed an intermittent loss of braking when almost at a stop, the pedal drops and then while you are worried about hitting whatever is stopped in front of you the brakes finally reengage. There is a service bulletin out for this so it's a known problem. Porsche is legendary for the brakes on it's cars. Why a needless and borderline dangerous complication blending two braking systems? The fix is a mechanical one rather than software but it's a result of designing a blended, software controlled, braking system.
