Jonathan S.
- Jonathan
- Jan 19, 2023
- Amherst MA & Twin Mtn NH
- Website
- tinyurl.com
- '22 4CT, '22 Audi A6 Allroad, '23 BMW i4 M50
90% of 84.3 = 75.87 kWh - call it 76@daveo4EV How are you arriving at "a full charge at 9.6 kW can take 10+ hours (from 10% or less to 100%)"? My calcs show ~8hrs with a standard 48a hardwired charger, and that matches up with my own experience. (Of course the PCM and app vastly overstate the time...)
I'm not sure how to answer #1 - the cables are available but in short supply - so it's unclear if the Porsche dealer your purchased the vehicle from, didn't have the cables, didn't remember to update you, will do it later, or does not plan to provide the cables.I ask all the following knowing the initial reaction is “buy another EVSE”. But I’d just like to understand if I can make what I currently have work.
I just took delivery of an on-lot Taycan that came with PMCC and a 25ft charging cable.
California, PG&E, extremely different overnight electricity rate vs afternoon. I have a NEMA 14-50 outlet that I previously used with Polestar’s included “mobile” charger, but I had to return that EVSE with the vehicle. I’m currently using another mobile EVSE I had, but it’s ~6.4 kW so I’d rather get this PMCC to work for now if I can.
- Should this have been delivered with the 240V NEMA 14-50 supply cable, or has that recall not been completely fulfilled?
- Since this is WiFi connected can I configure it with my electricity rates (and thus ideal charging times)?
I was eventually able to convince the local dealer to get me the 220V cable. They tried to pin it on the selling dealer, and the selling dealer said local dealer (I leased it from SoCal but am in NorCal). Too much back-and-forth. Regardless I have it now. One of the silly backwards-facing ones.I'm not sure how to answer #1 - the cables are available but in short supply - so it's unclear if the Porsche dealer your purchased the vehicle from, didn't have the cables, didn't remember to update you, will do it later, or does not plan to provide the cables.
#2 - the PMCC's wifi is useful for status checking and uploading charging statistics and getting OTA updates for the PMCC unit it self, configuring the unit to recognize vehicle VIN's if you want to lock out who can charge - it offers no scheduling/rate management - any management of charging time for PG&E off-peak usage will have to be handled via the PCM"s in car profiles/timers…
good luck!
Totally. I’m only even attempting this because the PMCC already came with this particular vehicle. I’m fully-convinced to not option it.I'd recommend a wall mounted charger for $700 or less
- ChargePoint Flex
- Tesla Universal Wall Charger
- Wallbox
- Enphase/ClipperCreek
- Autel
- others…
The warning sticker was already integrated the PMC+ which came with my 2023 Taycan and one which came with my 2024 Q8 eTron (a PMC+ with an Audi front plate sticker instead of Porsche). Both have now had the recall replacing the NEMA 14-50 cable with the thermal sensor (presumably, I actually haven't never plugged either of them into a live socket).Macan has introduced a "new" Porsche EVSE - called the Porsche Universal Charger - PUC…
on visual inspection it appears to be a warmed over PMC+ with:
I have no plans to use it, or even test it - but factually I have documented what comes with the Macan EV - and it's not much different that the PMC+ that we all know/love/understand.
- a new front face plate sticker with the "warning" sticker integrated
- new part number
- new name Porsche Universal Charger
- a slightly beefier attached J-1772 charging cable
- it came with what I'm guess is the "recall" NEMA 14-50 cable - it has the 8 gauge AWD wire stamped on the side and the plug-head facing the wrong direction
- so I"m going to guess it also has the thermal sensor
links updated on this thread #1 post - but provided below for quick access - if you're up to date on this thread here - there is nothing new in the Macan thread - it's simply posted for completeness…
https://www.macanevowners.com/forum/threads/first-sighting-macan-evse-charger-for-north-america….17007/#post-260101
Nice to know that Porsche is taking good care of new Macan EV owners with the Porsche EVSE.Macan has introduced a "new" Porsche EVSE - called the Porsche Universal Charger - PUC…
