- David
- Jan 28, 2019
- Santa Cruz
- Cayenne Hybrid, 911(s) GT3/Convertable
- Thread starter
- #1
for long time Porsche EV victims the saga of Porsche's confusion regarding the actual limits of their standard OBC (on board charger) and the regional limitations they have chosen (for undisclosed reasons) to enforce are a comedy or tragedy depending on your perspective.
In the rest of the world it seems all of their OBC's come standard with a confguration allowing a max L2 240V AC charge rate of 11 kW…
In North America the Taycan has been marketed alternatively as an 11 kW or 9.6 kW vehicle - with Porsche's own standard equipment details on their website offering confusing spec's in this space…
More recently Porsche seems to have settled on 9.6 kW (240 volts @ 50/40 amps) as the default maximum rate - there as been a factory option for 19.2 kW OBC but that also has been fraught with reliability problems, service parts restrictions and unclear lineage as to if the "new ones" are actually improved or simply the same old unreliable 19.2 kW OBC unit…
the North American Cayenne EV continues this proud Porsche tradition of an embarrassingly slow L2/AC/240V maximum charge rate for a $150k+ premium EV limiting itself to charge rates even a $25k Chevy Bolt would be embarrassed by …
The Cayenne has two "maximum" charge rates…which I find interesting
NOTE: it's reasonable speculation that there is no such thing in the parts supply chain as a 9.6 kW OBC - since all Porsche EV's ship with an OBC that can do 11 kW in other parts of the world. The 9.6 kW limit is a "choice" made by Porsche and a limit for the North American market that has never been fully explained…
So I can only charge my Cayenne at 9.6 KW but I can charge it at 11 kW wirelessly?
I've been thinking that's got to be wrong and simply confused marking materials. The wireless path is not subject to the North American "discount" charging rate of 9.6 kW? Then I realized - wireless charging is via induction - induction is Direct Current electricity (DC) - it's not Alternating Current (AC) electricity - so it's not being routed through the neutered 9.6 kW AC 240V OBC…it's probably being fed directly to the DC inverters/OBC's where we know the limits are much much higher…
I now I'm thinking we will have a comedic/tragic split in max charge rates for home charging:
- Standard Equipment is a 9.6 kW OBC - continuing Porsche's relentless march to be substandard in this space…
- The optional wireless charging is advertised as 11 kW maximum charge rate…
- use a "wire" to charge your Cayenne - 9.6 kW max power
- or pony up $1800 for the 19.2 kW factory option and cross your fingers it's a redesigned unit vs. the existing know fragile Taycan 19.2 kW units…
- use wireless - 11 kW max power
