- David
- Jan 28, 2019
- Santa Cruz
- Cayenne Hybrid, 911(s) GT3/Convertable
- Thread starter
- #361
for the 8 or fewer laps the taycan Turbo was able to do it's impressive for a 4 door sedan at 5,100 lbs - chasing down 911 GT3's uphill between turns 5 and entrance to the cork screw (turn 8A/8B) was a hoot - several 911 GT3 drivers came to inspect my vehicle and me as a driver after session - they were "impressed" with it behind them, passing them, and then in front of them and couldn't believe it had 4 doors…Indeed.
EVs are daily drivers.
Too heavy for racing, and road targeted versions not got the thermal capacity.
I was below 50% battery @ 132F battery temp with the cooling system running full bore on a 68F day at laguna seca - the Taycan needed about 30 min "resting" in the pit garages after the abbreviated session - and then it was just as good for the 2nd session - but lacking fast charging at Laguna Seca meant due to the depleted battery I could stay out even less time for the 2nd session - coming in at around 15% battery to have enough capacity to drive off site to local fast chargers…
I love my EV's but also know what they are, and are not, good for.
https://www.taycanforum.com/forum/t...d-on-driving-lap-data-impressions-added.2923/
the order in which you will "run out" of capacity on Taycan (and other EV's is as follows)
- first you will run out of battery thermal capacity
- second you will run out of tires (given the weight your street tires are overheated and greasy after about 8-10 minutes)
- third you will run out of actual "fuel" battery capacity
- forth (which you're never reach because you're out of fuel) you will run out of brakes
