Need info & real pictures for Cayenne EV Offroad Package
MP42
Northern CA
2015 Audi S8; 2020 Audi Q3; 2012 VW Golf R
Hi all-- Longer term member on another popular Porsche and Cayenne board. Their reach on the EV side seems light. I thought I would try here.
I was working this past Spring on a Cayenne E3.2 hybrid order. But too many leaks and spy photos were published some months ago that slowed me down--not wanting to buy a late-in-life-cycle model, with at least another facelift seemingly in the works. The big drop in price in pre-2024 models (prior facelift) makes that pretty stark to me too. Good for buyers, not so good for first owners. Plus the Euro 7 required changes are now working their way through drivetrains at least on the European side that may prompt a further faster turn facelift regardless. All caused me to take a hard look at the freshly minted E4 Cayenne EV, with a foray to the Macan EV until I decided it was too small for my spec...as was the Cayenne Coupe EV I looked at for a few weeks.
Question is specifically on the Offroad package for the Cayenne EV per the configurator. I think one person on the forum may have one from a passing reference in a thread. Unfortunately there are none locally or even regionally. Porsche does not even allow searching on it as an option, so you are left to sort pages of listings, only omitting ones with 20" wheels as a disqualifier. I eventually found 2 in the entire USA with same pictures.
What I struggle with are the actual colors of the material. I (sort of) like the look, and have some functional preference for it. But I am concerned how strong the rear fascia area looks in particular. I'll grant it does say "off road" in spades, but seems a bit much given rest of E4 look. If it were darker or less prominent (for a darker paint like Oak Green or some others) I'd be fine.
Tracking it down and reading the configurator material, the basic Offroad trim/cladding is satin black, but it has inserts in the front fascia, uniquely colored roof rails and the large splitter/lower rear fascia component in Vesuvius Grey. The configurator pictures the lower rear fascia as quite light in color--fairly stark I would say.The problem though is what is known as Vesuvius Grey Metallic by Porsche (and earlier, Audi) is a very dark grey. Many shades darker than this seems to be. The configuraor shows this as more as an aluminum or steel type metal color with heavy silver. The two available vehicles in the dealer listings have pictures where those pieces are fairly light too. It is also a wheel option for the intra-spoke inserts on one of the 22" choices.
So, anyone here with pictures for an actual built/owned Cayenne EV with this unusual package ? Any understanding of its (non?) apparent relationship to the normal "metallic" Porsche vehicle color--which can be found as a PTS color and then shows very dark. Bonus points for describing the (satin black) trim finish. In pictures it looks a bit lighter than the common Porsche gloss black. The surface also seems like it has a very fine texture. What I might expect for this kind of more rugged trim look. But from experience it looks like maybe the kind of trim where if wax gets onto/into that textured surface, it can be very difficult to remove/clean.
The Offroad Package consists of:
Offroad lower front apron in Black (matt) with inlay painted in Vesuvius Grey
Wheel arch covers and side skirts in Black (matt)
Offroad lower rear apron in Black (matt) with diffuser painted in Vesuvius Grey
Roof rails painted in Vesuvius Grey
Vesuvius Grey should match the standard wheel arch and side skirt colour.
Also note that the lower active cooling slats are horizontal rather than vertical.
TXSchnee
St. Paul, MN
‘26 Panamera GTS, '24 Cayenne S E Hybrid, '26 Macan Turbo EV, '26 Rivian R1S Tri
The Taycan CT had an option for the Off Road pack in Vesuvius Grey, may want to look on Taycanforum.com to get some decent real life pictures of the actual color.
MP42
Northern CA
Folks, thanks. I know what the option package is per the Porsche site. The problem is, what can I rely on real world for a configuration that can't be seen on a lot or even dealer color samples I have tried to find for Vesuvius Grey or trim
In the plainest English, I don't think Porsche knows what it is talking about in describing the color used for the front and rear inserts as Vesuvius gray, nor in the wheel colors where that is possible. Try this picture out, straight from the configurator for a 2027 Cayenne EV. I picked Vesuvius Grey from the PTS exterior menu as seen right there, and had picked a Vesuvius wheel choice and then the Offroad package.
Try to make any sense of the vehicle paint (described on web generally as close to black but maybe with some shares of blue, brown otherwise in varying light. If you search on it, those are the sort go generally darker colors you/I find. That's what the vehicle paint looks like to me in the PTS screens with that choice, but now try to make sense of either the wheels or the lower rear bumper/fascia splitter with the same nominal colordesription. Add to it, look at the bumper cover in the back just above that light area or around the fender wheel openings, which the description of the Offroad package would have you you believe is matte or satin black. That's pretty obviously a web color presentation issue/fault from some pictures I'll post next.
Porsche Cayenne EV Need info & real pictures for Cayenne EV Offroad Package Screenshot 2026-11-23 at 5.24.28 PM
Porsche Cayenne EV Need info & real pictures for Cayenne EV Offroad Package Screenshot 2026-11-23 at 5.36.55 PM
