What tyres? Cayenne Turbo
IanDB
Ian
www.youtube.com
We’ve had amazing weather in the uk since I picked up my Turbo in July. Today, the heavens opened and I was caught a little surprised with the summer performance tyre’s on the Sport Techno 22” wheels.
in comfort mode, a little push coming off the roundabout and a nice 4 wheel drift!
Nothing too horrible and easily corrected but it did start me thinking that some all season tyres may not be a bad idea as the weather starts to get worse.
Any suggestions for good grip and low road noise? I don’t mind the price but I do want decent grip and low tyre road noise.
The Cayenne EV turbo tires were specially created by Michelin’s Top Performance Car engineer (he and his team also did the tires for the 1,250 HP Corvette ZR1 X); with the Cayenne’s 1,137 HP and 1,106 TQ, its tires had to be specially created. I wouild be doing extra diligence to find A/S tires that can handle its massive HP/TQ.
https://www.thebuzzevnews.com/pirelli-cayenne-electric-tires/
A P Zero R supports the high-performance Cayenne Turbo. The range also includes two winter fitments and one all-season tire. All six fitments use Pirelli Elect technology for electric and plug-in hybrid vehicles.
P Zero R Supports Cayenne Turbo
Pirelli developed a dedicated 22-inch P Zero R for the Cayenne Electric. The tire uses separate front- and rear-axle specifications.
The fitment supports the performance requirements of the Cayenne Turbo. The vehicle accelerates from zero to 100 km/h (approx. 60 mph) in 2.5 seconds.
Pirelli said it used an ultra-high-performance compound derived from its motorsport programs. Its performance is close to the semi-slick P Zero Trofeo RS. The tire uses the same compound developed for the Porsche 911. Pirelli adapted it for the Cayenne Electric’s weight and wear requirements.
Axle-specific compounds and an optimized contact patch support longitudinal traction. They also help maintain stability and steering response under instant motor torque.
Winter and All-Season Fitments
Pirelli developed the Scorpion Winter 2 as the approved winter fitment. It is available in 20- and 22-inch sizes. The range also includes a 20-inch Scorpion MS All Season tire.
IanDB
IanDB
Ian
www.youtube.com
Thanks.
it also looks like Michelin do an equivalent in all season for the sport techno wheels on the turbo
mrmax
Max
Palo Alto
25 Taycan TurboGT, 25 Cayenne EHybrid, 23 Bronco Badlands
I need all season tires for my inbound Turbo Coupe LW - seasonal snows aren’t a good solution when you winter use consists of trips between the Bay Area where it will often be 60s and dry in winter, sometimes reaching 70s - not good for snow tires - and Tahoe, where it will often be 20s and snowy where summer tires just won’t work. I don’t want to switch my tires in Auburn, so all seasons are basically mandatory.
The two options I found in the stock sizes (285/40 22 and 325/35 22) are Pirelli Scorpion Zero All Season (Aston Martin OEM fitment) and Michelin Cross Climate 3 Sport.
Going down 10mm in width opens up more options and should be possible but I prefer to stick with stock sizes so I didn’t look as carefully at those options (which may also vary by geography).
Both look like reasonable options. Pros and cons, not all of which will be relevant to all potential buyers:
- PZAS is stupefyingly expensive (close to $4k a set)
- CC3S is certified for severe snow (3 peak mountain snowflake symbol); PZAS is not
- CC3S is not sold by Michelin in the US
- Don’t know about PZAS availability outside US
