Wheel Specs same between Cayenne EV and ICE?
Agswin
College Station
2026 Cayenne Electric
Does anyone know if the Cayenne Coupe electric has the same wheel specs as the standard cayenne?
mrmax
Max
Palo Alto
25 Taycan TurboGT, 25 Cayenne EHybrid, 23 Bronco Badlands
Not the same.
EV has lower offsets and a larger difference between front and rear width.
Agswin
College Station
When selecting new tires, do they need to be EV specific?
mrmax
Max
Palo Alto
Your tires need to have a sufficient load index for the weight of the vehicle. Usually tires in the same size will have a similar load index but not always. They also need to fit the rim widths (which differ significantly front to rear) while having the same diameter front and rear.
Unless you have a really good reason, just go with one of the OEM options - which are available online at sites like tire rack as well as at dealers. Those sites make it easy to find tires that fit your vehicle and filter for the OEM choices which are designed to work well with the car.
Unless you have specific requirements and a fair bit of knowledge, I would avoid second guessing Porsche’s choices for a critical component of the car.
Agswin
College Station
What are the $600 OEM upgraded tires for the 22” wheels on the Cayenne coupe S and turbo because I will need to buy them after I get the car.
What I’m finding online is that it’s one of 3 tires but can’t find the actual one.
Agswin
College Station
Answers I get
The 2026 Porsche Cayenne S (with optional 22-inch wheels) ships with staggered, electric-vehicle-tuned performance tires. The factory original equipment (OE) tires are Goodyear Eagle F1 Asymmetric 6 (front: 275/40R22, rear: 315/35R22) or Michelin Pilot Sport EV or Pirelli Pzero 4 tires with the Porsche "ND0" or "NF0" approval markings
mrmax
Max
Palo Alto
There are two different widths of 22 inch wheels available and each comes with different tire widths.
If you choose a specific wheel on the configurator, once it’s in your build there will be a little i in a circle next to the wheel you picked, and you can click on that and it will show wheel and tire widths. Choose the one that matches your wheels on tire rack or wherever and then you can filter for OEM in the search.
I am sure your dealer can also provide this information for your specific config, or whomever is selling you the wheels you are swapping in.
Agswin
College Station
The dealer does not know which brand tire comes with the wheel and the configurater doesn’t show the brand either so I guess we will have to wait and see when cars start hitting the dealerships
22" Performance Summer Tires
Performance summer tires with very good dry handling properties for dynamic driving while still offering good wet-handling characteristics in daily use. Suitable for sporty use on the racetrack.
Note: Only available in conjunction with 22" SportTechno Wheels or 22" Lightweight Sport Wheels.
Was this information helpful?
mrmax
Max
Palo Alto
The only OEM tire in the size for those wheels is the Pirelli PZero R
