Taycan Wheel & Tire Specs -- Bolt Pattern, Center Bore, Thread Size, Offsets, Tire Sizes
Administrator
Administrator
All 2020 Taycan Models
Center Bore71.6 mm
Bolt Pattern5x130
Wheel FastenersLug Bolts
Thread SizeM14 x 1.5
2020 Porsche Taycan 4S
Wheel Sizes | OffsetsTire Sizes
9Jx20 ET54
11Jx20 ET60
245/45ZR20 103Y
285/40ZR20 108Y
8Jx19 ET50
10Jx19 ET47
225/55R19 103V
275/45R19 108V
9.5Jx21 ET60
11.5Jx21 ET66
265/35ZR21 101Y
305/30ZR21 104Y
2020 Porsche Taycan 4S Plus
2020 Porsche Taycan Turbo
9Jx20 ET54245/45ZR20 103Y
9.5Jx21 ET60265/35ZR21 101Y
wmras
Bill
Oregon
Taycan TS, GT4 (sold), Macan Turbo, Cayman SBE 987.18
You need a 19 mm socket. I am happy with this set from ECS Schwaben long reach socket set P/N PPS-1721LC. It includes 17mm, 19mm & 21mm.
Have had good luck with:
Tire Rack Steel Man 5PC SOCKET SET WITH NYLON SLEEVE
Genau
Dan
Reston, Virginia
2020 Taycan 4S
I'm told these are the largest rear tires ever installed on a Taycan, and they work perfectly. Here are the details compared to the original 20" Turbo Aero wheel set.
Porsche Cayenne EV Taycan Wheel & Tire Specs -- Bolt Pattern, Center Bore, Thread Size, Offsets, Tire Sizes 855492F3-A7E6-421E-82DE-923204C33B74
Mathys
Heerlen NL
2022 X3 30e
Any chance you could add the thread length of the OEM bolts?
mjw930
Mark
Central Florida
'14 Cayman S 6M, ‘24 Ridgeline, Taycan 4SCT (sold)
Jonathan S.
Jonathan
Amherst MA & Twin Mtn NH
tinyurl.com
Will a 71.5 bore size wheel fit on the Taycan?
If the tolerances are tight, then obviously not.
But this seller:
https://www.ebay.com/itm/167522822380
... lists a 71.5 bore size and compatibility with various 71.6 Porsche.
(I will of course also ask the eBay seller.)
I just want to build up a full-size spare to keep up at my mountain house up north.
(I had thought about doing this before, then never got around to it, but today ... well, maybe I'll post pictures in the scenery thread!)
