- Jul 30, 2021
- WA, USA
- 2023 Taycan TCT, 2024 Q8 eTron P+
Good first order calculation, however I would look at it from a different point of view. I think we can assume that total amount of energy (kWh) to be delivered to the EVs would be the same, i.e. all EVs that wanted a charge, got what they wanted. So now the issue simplifies to flattening the utility power delivery curve, or time shifting the power delivery. This can be accomplished by having on-site energy storage (batteries, super caps, other means like mechanical energy storage) at the DC charging stations to smooth out the load. How many batteries would be needed of course will depend on how many cars per day do you need to service, how much energy they need at what speeds, and their distribution throughout the day. I suspect a decent size station with all load balanced stalls and shared battery bank would not require that much battery storage - some cars will be charging slower than others, and the surplus energy will be stored for the next car which requires a high power burst. Worst case scenario during a busy holiday, charging gets a little slower, but then again during busy times lines form at gas stations too.yeah it's interesting - really really fast charging is only part of the picture - you have to have enough delivery power to then provide ### kWh's in "mm" minutes…
Macan is 100 kWh battery - 95 kWh usable
10% -80% is 70% charge - 70% of 95 is 66 kWh + 10% charing loss overhead is 73 kWh
73 kW charge rate = 1 hour to charge from 10% to 80%
146 kW charge rate = 1/2 hour
292 kW charge rate = 1/4 hour
876 kW charge rate = 5 minutes
now let's scale that to 10 stations at a commerical charging site
you need 8,760 kW power feed to charge 10 EV's in 5 minutes - 10 megawatts…to charge in 5 minutes for a 10 station stall - some entire power plants are only 40 megawatts…so 1/4 of a power plant to charge in 5 minutes if you want to scale to 10 EV's at once…
as your shrink the charging time you seriously increase the power input requirements because we're compressing time - and that's expensive.
