[Opinion/PSA] - you don't need or benefit from PCCB's on an EV w/excellent regeneration…
this is my $0.02 YMMV
tldr; save more than $11k (option price, tax, registration fees) on your Cayenne EV build by not optioning brakes that will only be used 3% of the time - Porsche's own data/claims.
Porsche Cayenne EV [Opinion/PSA] - you don't need or benefit from PCCB's on an EV w/excellent regeneration… Screenshot 2026-07-24 at 2.36.06 PM
details below…
We all know Porsche _LOVES_ their options list and increased margins associated with these mostly excellent choices options. One of Porsche's stand out options for over a decade has been the option to add world class ceramic brakes to their vehicle's - which by any measure are the best brakes mass production money can buy. Now PCCB's have pro's and con's, but at this point in time they are a well sorted choice and the Pro's/Con's are well understood for the well informed buyer.
This option is also one of the most expensive factory options you can add to any Porsche vehicle…
I've been a Porsche victim since my first 2008 911 4S - and have purchased and optioned many many different models of Porsche's - normally PCCB's are a deep-heavy-sigh but yeah go ahead and check the box…because they are in fact the best brakes you can option, and the factory option is the cheapest method to obtain these outstanding and high quality brakes.
however we are no longer in the same space as we are with Porsche's high quality ICE vehicle's - and there is a new techology all these fancy EV's come with.
Regenerative braking by Porsche's own admission handles 97% of your Cayenne's normal use and therefore the friction brakes are far far less used on any decent EV…3% or less of the time by Porsche's own data and claims!
The Porsche Cayenne Electric handles energy recovery through an advanced regenerative braking system, capturing up to 600 kW of power and managing about 97 percent of everyday stops without physical brakes. Porsche does not use a one-pedal driving mode; instead, it relies on blended braking where pressing the physical brake pedal engages the electric motors for deceleration before seamlessly adding friction brakes. [1, 2, 3, 4, 5]
How Recuperation Works
  • Blended Pedal Operation: Lifting off the accelerator provides light deceleration or coasting depending on settings, while pushing the brake pedal activates motor regeneration first. [1, 2]
  • Formula E Tech: Direct oil cooling on high-end motors allows the system to harvest massive amounts of energy safely without overheating internal components. [1, 2]
  • Reduced Wear: Mechanical brake pads see very little use, meaning they experience minimal wear over the vehicle's lifespan. [1, 2]
Adjusting Settings
  • PCM Menu: Navigate to the car menu, select drive, and tap the recuperation icon to toggle overrun settings.
  • Steering Wheel: Program the customizable steering wheel button (joker key) for quick on/off toggling of overrun recuperation. [1]
Would you like to know more about the charging speeds, battery capacity, or driving range of the Cayenne Electric?
https://spectrum.ieee.org/porsche-cayenne-electric
For most drivers, those friction brakes won’t get much use, though:
The Cayenne makes about 97 percent of its stops in typical driving using regenerative brakes alone, Porsche says. Those regenerative stops return up to 98 percent of available kinetic energy to the onboard battery, nearly matching the company’s Formula E racers for efficiency.
this difference between ICE vehicle's and EV's can give us pause to reconsider the value proposition of PCCB's on a vehicle that rarely if ever actually uses the friction brakes!!!
PCCB's 3 main super powers over Porsche's excellent cast-iron metal brakes are:
  • lower weight
  • lower dust emissions for cleaner wheels
  • thermal endurance under heavy use (never fade)
Well 2 of the 3 "super powers" don't generally matter on an EV 98% of the time
  • weight always matters - but I'll argue on a 6,000 lbs vehicle - you've already lost - so this $11k+ option isn't going to be that much a "win"
  • low dust - still true, but doesn't matter if the friction brakes are never/rarely used
    • on an EV with excellent regeneration friction brakes are rarely used and wear even less - no dust if there is no actual wear…
  • thermal endurance - this one is counter intutitive - but again - regeneration means the friction brakes are not used and therefore do not thermally "heat up" in nearly any scenario for normal driving
    • where you would need thermal endurance is for track or very very spirited driving over long periods of time - but even in that case because of consumption and other limitations you run out of "capacity" in other components (battery thermals and actual total capacity) of an EV before you're going to thermally saturate the friction brakes…
    • based my actual track experience with my 2020 Taycan Turbo - you simply can not drive an EV hard enough and/or long enough to need high-endurance brakes…you can't be on track long enough to "need" high endurance brakes
Also it's important to remember: Porsche normal cast-iron standard brakes are the best in the industry and simply excellent on their own. Other vehicle owners buy after market upgrades to get brakes that are as good as Porsche's normal factory standard brakes. So you're not losing out, the factory standard cast-iron brakes from Porsche are simply excellent on all their vehicle's and the envy of the industry and other car owners…Porsche's standard brakes are excellent by any measure!
I believe this is an excellent place to save money on a Porsche build for an EV…and will never be missed…and you also avoid the cost of repair/replacement should that come up for some reason (PCCB's are with out a doubt deeply expensive to replace/repair should it be required) - it can easily and nominally run more than $30k to repair/replace all 4 PCCB's rotors on any of Porsche's PCCB vehicle's. PCCB's are not fragile, but they are less resilient to certain types of road hazards than normal cast-iron brake rotors and should them become damaged or compromised they are simply expensive to replace. They may in fact be a terrible choice for an SUV that actually will used used on gravel/dirt/poorly-maintined roads…it's worth considering where/how you intend to using your Cayenne EV before checking the PCCB box.
in fact regeneration is so effective one of the most challenging hill decents in the world (pikes peak) - the Audi eTron's brakes rotor's were thermally measured to be at ambient air temps at the 1/2 way mandatory ranger check point when they were testing it…
if you want a testimonial about how little friction brakes are used on an EV look no further than the eTron testing data from pikes peak in 2018…
https://www.cnet.com/home/electric-v...-braking-test/
“Do you want to touch the brake disc?” As far as questions go at an automotive press launch, this was a first for me. Dr. Michael Wein, the manager responsible for the new regenerative braking system on Audi’s E-tron electric SUV, leaned in and said, “Go ahead.” I admit, the thought hadn’t exactly occurred to me. Mere moments ago, we had descended from the 14,000-foot summit of Colorado’s Pikes Peak, pausing part of the way down, at historic Glen Cove Inn (altitude: 11,500 feet), for a mandatory park ranger brake check.
The ranger dutifully popped out of his little wooden guard shack with a pistol-grip infrared thermometer, pointed the barrel at our car’s front disc, and crisply announced, “forty-seven-point-nine degrees.”
At that point, we had only descended around 2,500 feet, but by then, the ranger assured me, most car brakes are sitting at an easy 150 degrees Fahrenheit, and some are a good deal hotter, with a small percentage already overheated at 500 or worse (at which point they’re typically billowing smoke and our park ranger friend orders to pull over and cool).
Our Audi E-tron prototype’s discs, by contrast, were sitting just a few degrees above ambient temperature. I know, because I dutifully put my hand directly on the disc on and checked, to Dr. Wein’s visible satisfaction.
A steep 2,500-foot descent, and we had barely had occasion to graze the discs.
I see no reason to upgrade the brakes on an EV w/regernation above and beyond Porsche's _EXCELLENT_ cast-iron "standard" brakes - even Porsche's non-PCCB brakes are considered excellent by most any standard…so this are of the vehicle is not a place to dump options money.
Also; since 2018 manufacturers have been improving and increasing regeneration capabilities such that regeneration is even better than it was in 2018 models and therefore more effective using the friction brakes even less than in the past.
my $0.02 YMMV - but you can save more than $11k on your Cayenne build (plus registration and sales tax on the $11k) by skipping this option on an EV build…
food for thought - you simple don't need or really benefit from PCCB's on a high-regeneration modern EV - they are of dubious benefit and quite expensive in the grand scheme of things…
I still option PCCB' s on current and future ICE Porsche's - but until I can run a Porsche EV on track at/near full pace for more than 45 min straight - PCCB"s are not part of any my future Porsche EV builds - it is simply money better used for other options or outright savings…
aileron
Alex
Denver, Co
992.1 Turbo S Cab, various others
I think there are advantages of the unsprung weight savings from the PCCBs also, in acceleration, ride quality and overall handling.
With less weight to control in the wheel/tire/rotor system, the suspension can respond faster and impacts couple less to the rest of the body.
my opinion is these are inconsequential on a 5000+ lbs vehicle and certainly not worth the 11k entry price - but it _IS_ the _ONE_ remaining benefit of PCCB's…
each owner is welcome to determine if the weight savings is worth while vs. the $11k price to play in the sandbox.
For a daily driver SUV who's average speed over the life of the vehicle will be 38 mph or slower - yeah show me!
frankchn
Bay Area, CA
GT4RS, Cayenne Turbo Electric
In this case, I think the right call might be to pick Active Ride over PCCBs.
I suspect body control with PAR + steels is going to be significantly better than standard air suspension + PCCBs, due to the ability for PAR to "inject" energy into the system instead of just adjusting damping or ride height.
Of course, if money is no object, get all of it for the best experience.
this guy also agrees apparently - PCCB's are pointless on an EV…
"Great. And because it has this 600 kilowatt regenerative braking system, which is a lot. That's a big number. That's humongo. Yeah. The Hummer EV was the former big one was like 400. So because of that, you don't need ceramic brakes. Like the regenerative braking really does like 95% of the braking work."
details below…
  • lower weight
interesting follow up from Formula-e
I had the pleasure of a dinner with Antonio Felix da Costa - Jaguar's (formerly Porsche) Formula-e Driver - https://www.jaguar.com/en-us/jdx/jaguar-racing/index.html. - London Formula-e Final race Aug. 2026 with Chase Sapphire Reserve Experiences!! - https://www.chase.com/personal/events/experiences
Porsche Cayenne EV [Opinion/PSA] - you don't need or benefit from PCCB's on an EV w/excellent regeneration… Screenshot 2026-09-05 at 7.54.24 AM
Porsche Cayenne EV [Opinion/PSA] - you don't need or benefit from PCCB's on an EV w/excellent regeneration… IMG_3665
it was a pleasure to spend the evening at dinner with such a talented driver and racing enthusiast - and long time EV driver…
Formula-e gen 3 and gen 4 cars have NO REAR brakes - regen only!!
and the front brake rotors are insanely small…for a race car this made no sense to me…
Porsche Cayenne EV [Opinion/PSA] - you don't need or benefit from PCCB's on an EV w/excellent regeneration… IMG_3028
well both Antonio and the Jaguar head mechanic explained it to me…
Regeneration is so effective - that the front brakes are really only used during qualifying laps - not much if at all during the race…
Antonio confirmed this in conversation at dinner - he has brake bias and regen-vs. friction controls on the steering wheel during the race and qualifying - he mostly does not use the front friction brakes - and when he does it's only at certain corners during his "flat-out" qualifying laps at certain tracks - even for qualifying at some tracks he can go flat out regen only - the rest of the time it's all regen!!
this is the same technology that Porsche has in their EV's - and the latest regen tech from Formula-e is in the Cayenne EV…600 kW of regeneration is no joke and leaves your friction brakes just mostly along for the ride except in a very few circumstances.
so unless you're doing qualifying laps in your Cayenne and know which corners you need the friction brakes - this $10k option is entirely cosmetic…because during the race regen carries the deceleration loads and the friction brakes are entirely unused.
I found this chat to be engaging and fascinating and it was a real treat to spend an hour or so with such an accomplished athlete at the top of their game in a sport/hobby/subject I'm so personally interested in…
Do you mean in the future, or is it already in?
600 kW regenerative braking _IS_ in the Cayenne EV - Porsche has been very open about formula-e feeding tech to their road cars…in this case Formula-e is an extreme use case but I was blown away by the _FACT_ that they don't even use their wimpy friction brakes during a race - only during qualifying- that's how good regeneration is…formula-e experience has given all the manufacturers the confidence with regernation that they can start relying on it more and begin the process of lowering the friction brakes roll in deceleration…
basically the friction brakes on a road going EV are there for a few reasons:
  • safety - as a back up system - yeah they are a fail safe…
  • for the rare extreme use case of full on panic stop
    • (again you need friction brakes for this but you don't need PCCB's - tires stop the car in a given distance base on grip levels, not the brakes - same tires same conditions same speed same brake force steel brakes to the car int he same distance as PCCB's)
  • braking for when the battery is full and there is no place for the regen to go
  • probably for buyer confidence/perception - I don't think people are ready to purchase a car with "no brakes"
    • I predict however we'll start to see EV's with no rear brakes…
  • stability control. currently Porsche uses all 4 brakes for (individually) for stability control since they can use each corner to help stabliize the car under certain circumstances…
but yeah your Cayenne EV has 600 kW regeneration and Porsche's _OWN_ claims/data are that regeneration handles 97% of all braking over the life of the vehicle…
so the $10k PCCB option is for handling 3% of your braking load over the life of the vehicle?
I'm not saying we don't need friction brakes…
we do 100%
I'm saying we don't need PCCB's - who's main super power is "endurance" braking … high thermal loads for fade free endurance racing is PCCB's party trick.
Porsche's excellent steel/cast-iron brakes are more than up to the task of handling 3% of your Cayenne's life time braking needs…the front an rear rotors on your Cayenne EV are simply stunning and can easily handle anything you will throw on them - even on a track should that ever happen…
you'll run out of battery and tires long before you overwhelm the brakes…for any track or spirited driving.
Porsche Cayenne EV [Opinion/PSA] - you don't need or benefit from PCCB's on an EV w/excellent regeneration… Screenshot 2026-09-05 at 8.22.07 AM
